first log run..need help
90 Talon AWD
148
Aug 27, 2008
jonesville, North Carolina
this is my first log with my talon back running, any pointers? i know my airflowperrev is high but i havent fully understood how to get it down, im a semi noob at tuning, also it does have about a 1/4 tank of 2 year old gas, with anout 2 gallons of fresh 93, another thing is that i know i need some bigger injectors and have some precision 1000cc's, so any advice on tuning them will be greatfully appreciated! thanks
First i would drain the old fuel, then put some fresh in. do a boostleak test and verify that the base timing is set to 5 degrees btdc. then post up an idle log at full operating temp. then we can help you get a handle on it.
