Wheels dangerously locked up while driving
nastyleak
93
Oct 14, 2010
Mobile, Alabama
Driving about 45 mph and surprise the POS locked the wheels up bringing the car to a skidding stop. The car stopped in the middle of the road and it was really hard to get it moved out of the street, lots of tire smoking clutch launches before fi
nally moving again. So this is ei
ther the transfer case or the center diff, maybe both?
The Trans just got new fluid month ago, and there are no obvious signs of leaks from the transfer case or under the car. Why would it lock up and what would cause this to happen?
Lack of fluid is usually the cause and the only way to test which drivetrain part locked up you'll need to drop the driveshaft and check the transfer case and rear diff to see if they turn freely.
:dsm:
You can't blame him for trying to get it out of the middle of the street, at that point you've got to decide if you'd rather repair/replace damaged parts or total the car and possibly kill a family driving down the road.
:dsm:
The rebuilt engine was installed about 6 weeks ago there have never been any visible leaks from the TC and I've been under the car lots of times in the past for various reasons. maybe the fluid drained from the tc when the trans was removed and they forgot to replace it? Waiting for a flatbed to show up wasn't really an option parked in a 45 mph highway.
Just to be clear, a shop did an engine installation for you [which requires removal of the xfercase, unless you're a wizard] and what else, exactly?
I'd want to know if BryanWheat would consider it standard practice to inspect the fluid level of the xfercase if it were removed for any reason during a service. Or if there's a service at all that would call for that behavior.
You are a lucky guy for not getting into an accident. Sounds like they forgot to put fluid into the transfer case (if you didn't see anything leaking and was bone dry)
either because the tech forgot or he believed someone that told him
"You dont need to put fluid into the transfer case. It gets it from the tranny." :ohdamn:
The recall was performed years ago, the transfer case shouldn't have lost it's fluid by being removed.
Thanks for calling me a calling me a wizard.
And at a shop it should ALWAYS be common practice to check every fluid level on the vehicle. Its how you cover your ass and also how you make money. As Im sure if you brought your car to me to swap an engine or whatever and I told your t-case fluid was low, that you would tell me its ok don't worry about it.
  • For sale NEW Magnus Forged Transfercase gears PENDING
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
