Front wheels locked up while driving
Carlz0r
305
11
Aug 30, 2006
Vernon, BC, Canada
Picked up my car after some work and a dyno tune yesterday and it was running flawlessly. Did a few pulls and as I was slowing down approaching a red light, it felt like someone had locked on the brakes as the car stalled out while coming to a stop. Got out and tried to push it and I couldn't get it to budge more than an inch.
After getting it towed back to the shop, the mechanics jacked the back end of the car off the ground and confirmed the rear wheels spun fine, however when they lifted the front end and spun the wheels they would only rotate partially and would then bind and pretty much lock up completely.
Tranny is getting dropped out for inspection but I'm curious if anyone has ever dealt with this before (haven't been successful with any searches) and if so what the cause is or may be?
Remember, your're an AWD unit with a viscous coupler in the tranny - why you couldn't push it since all axles had locked up.
Rear axle locked up causing the coupler to lock up the front axles.
Check into the coupler .. it could have gone bad on you.
Or, you could have a low tire that caused one axle to turn at different RPM and this will cause the coupler to lock up quite easily.
DSM
DSM
The rear wheels turn fine though, we verified that it's indeed only the front wheels which lock up. Wouldn't a bad VC cause the rears to also lock up?
Even if the vc was locked it wouldnt stop the car from rolling or driving, it would be the same as using a vc eliminator or welding the vc.
Ended up being a broken CV, however the shop who swapped in a new rear end for me didn't put any fluid in it so it's trashed.
  • For sale NEW Magnus Forged Transfercase gears PENDING
    Parts are new never used. Get some nice parts for a couple bucks off.If I don't replay right...
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
