Tiki2777
- 1,100
- 143
- Oct 9, 2011
Omaha,
Nebraska
So I discovered my wheel bearing was bad, and I used PB blaster on it and a slide hammer. However, the hub didn't separate from the knuckle, instead the bearing came apart so there is still the other half stuck in the knuckle...
What the hell should I try to do at this point? Should I do something to get the rest of the hub off or just get the rest of the bearing out and press another in? Thanks
UPDATE: FYI, I got it out by getting the axle out of the way (2 bolts for ball joint and LCA) and beat it out with a BFH.
