Whats wrong with my motor??!
OZgsJames
33
Aug 13, 2011
Rockland, New York
im a newbie so it says i cant post this in engine management, sorry about that.
anyways i drove to school for the first time today and this happened.
420a problem PLEASE HELP - YouTube
i dont care if you comment on youtube or reply here, just tell me SOMETHING
it sounds like grinding/squeaking comming from the piston closest to the timing belt
rebuild or 4g63 swap time. sounds exactly like a spun bearing and I would stop running it if you still are as the damage can get alot worse the more you drive or let it idle
Definatly sounds like you are going to have to pull the pan and look for damage. I wouldn't drive it anymore at this point.
befor you go pulling the pan I would get under the car and reach up and see if the alternater pully wiggles around.Sounds to me like the alt bearing is shot.Also open the timing cover and see if the belt is loose.what ever you do dont run it untill you find the problem
THANKYOU ALL FOR THE INPUT
IT TURNS OUT THAT IT WAS A BAD WATER PUMP
so not that big of a deal LOL
Everyone saw it was a 420 and thought, rebuild or some crazy shit. Remember to start small and then escalate.
Cool deal. That pump is driven off the timing on those, right? That could be why it sounded like it was internal.
Yes, it is driven off of the timing belt.
OP, make sure to replace all of the timing components when you change the water pump. You have to take it all off to get to the pump so now is the best time to replace everything.
What do you mean by "everything"? because i was just going to get a new belt and pump
VelocitàPaola;152724393 said:
Most people usually replace the timing belt, tensioner, idler pulley and water pump when they have to pull the timing belt.
Yes this ^^. I would highly recomend that you replace all of the components seeing as how your car has 124k on it. If it still has the stock tensioner and pullys you would be running a huge risk of having one of those pieces fail.
well, im trying to find all these parts for cheap ### im nearly dead broke. And my concern now is to just get the car running again. It stalled out on me today and wont start up again. Throwing codes p0340 nd p0108
if you are looking for some stuff pm me i still have some stuff left from my 420a
With the 420a you can get a lot of power if you rebuild it or turbo it but when you turbo you have to run barley any boost i honestly think the 4g63 i a better way to go
Is that a fact? So how am I running 28 lbs of boost at nearly 55 lbs/min of air? Stop trying to up your post count by adding meaningless/hearsay comments.
Yuck. I'd hate to think that the water pump got so bad that it threw the timing belt......
MB
MB
yea, well a few days later the belt snapped and bent valves. Its all rebuilt now. Just have to drop it in and hook everything back up
