What's the difference between P and D?
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
This is probably a stupid question, but I am really trying to learn the complexities of the automatic transmission.
I've been severely neglecting my 97 Tsi awd, and since I "sold" her to my GF I've only been doing the necessary maintenance on her. She always felt sluggish boosting uphill. She also has always sounded like a jetliner taking off, which I realized later on is way too loud for only having an injen intake and evo bpv.
Anyway, I've come to realize she has what sounds like a massive intake leak somewhere around the manifold, but only in Drive or reverse, never in park.
When I put her in drive with the ebrake on I can hear this whooshing/hissing sound and when I squeeze the stock UICP it changes pitch. I will be doing a thorough BLT shortly, concentrating on the manifold gasket, injector o rings, egr gasket, vacuum lines, etc.
But in general, on an a/t what is the main difference between Park and the other gears? I realize it's under load when disengaging from P, but why does the intake tract all of a sudden start sucking so much more just shifting gears? Thanks in advance.
About 1100 in P and 800 in D, and idles perfect. I finally got around to putting on a rebuilt TB and deleting cruise control yesterday and noticed a big improvement; I knew the shaft seals were shot awhile ago. But is still here this whooshing sound in gear, even at idle. I plan on doing another BLT Monday directly on the TB elbow.
Actually, 750-800 in park is too low. 900-1100 in park is optimal for an a/t DSM, since it will drop to 750-800 in drive (optimal idle). If it was only 800 in P it would drop to 500 in D, too low. That's factory specs (stock cams) as I had done a ton of research a few years back when tackling an idle problem on my first a/t DSM.
And in my own experience, that's where they perform best.
No need for a video, as you wouldn't even hear the hissing over the engine noise. It's definitely a leak in the intake tract, I'm only asking why it's only prevalent when put into gear. Thanks
