jayman089
- 357
- 1
- Aug 16, 2005
Woodbine,
Maryland
Sorry for the newb question but what is the difference between a test pipe and a hi flow cat? is one of them illegal?? thanks in advance
yesjayman089 said:do you guys think that i would get pulled over a lot more with a test pipe rather than a high flow cat?
I don't know if I for one would take this information and run with it. Persnonally just let go of the few extra bucks pickup a LEGAL high-flo cat and let it be. That's the best option personally since you have emissions...250rmike said:i see your from Maryland. if you really want a test pipe drop the car down as low as you can get it. when they try to put you on the rollers and cant they will just pass you.
jayman089 said:so if i were to get a high flo then i would still pass emissions and i could get one welded on and wouldnt have to get a bolt on correct?
250rmike said:i see your from Maryland. if you really want a test pipe drop the car down as low as you can get it. when they try to put you on the rollers and cant they will just pass you. i have never had a visual inspection from the veip. yes a hi flow cat will pass visual inspection though. if any question were asked if they did check just tell them a muffler shop replaced it a while ago.
