What Turbonetics Turbo is this??
snowmansdsm09
236
6
Jan 26, 2005
Cheyenne, Wyoming
It has a T3 Turbine Housing... w/ a .63 ar
The Compressor housing says 60-1 on it
The wheel has 7 fins which I have read is the 60-1 wheel...
3' in and 2' out
What would this turbo be called?
T3/T4 60-1??
How much CFM will it flow?
I'm currently running 550cc injectors on my big killer t28... I'm going to have to get 650's?? or 720's????
Suggestions would be great!
The turbine is most likely a stage III correct?? How do I tell?
Thanks
Sorry so many questions, but I know people hate guessing at turbos without good descriptions so I gave ya'll everything there is on the turbo.
That's a good descriptions. If the information is correct then it is a T3/T4 60-1. It's a pretty good turbo, a lot of people on this site use it or the bolt on version. You would need 750cc or larger injectors along with all of the other supporting mods.
Here's the compressor map: http://turboneticsinc.com/cm_t4601.htm
Awsome! I'm really feelin good about this turbo now...
I've read it puts down nearly 800cfm !!! WOW...
My BKt28 puts down only 550...
So I need to look into 750cc injectors?
Any other sugggestion before I put this bad boy on!?
BTW, I'm going to put tubular manifold on it and an external wastegate, would that be my best option?
