Resolved What turbine housing is this
Dstarperformance01
880
174
Mar 5, 2016
Mustang, Oklahoma
I'm trying to figure out what turbine housing is this? I've searched with no luck. I do have the attached info with the casting number but those #'s aren't listed. Any help or info would be greatly appreciated. Thanks
Is it cracked right at the opening? Is that what I see?
Cracking around the flapper on a 6cm2 housing is basically standard at this point....as long as nothing protrudes through to the exterior anywhere you should be fine. The first photo made it look like it was possibly cracked to the outside just below the flapper lever in the pic.
