what tool for rear diff?
1Gina2G
810
May 6, 2011
Beaufort, South Carolina
what tool is needed to get to the oil fill bolt on the rear differential? none of my tools can seem to reach the bolt without getting in the way with some kind of line, maybe a brake line?
If i'm reading your post correctly, you simply want to fill/check the level of lube in your rear diff. I have 3 GSX's and all have a plug in the case cover on the back of the diff that takes a 17mm wrench. The only thing in the path should be the sway bar, but you should be able to get to it easy enough. However, it will be tight!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
