Rear diff bushings
krygods
52
4
Mar 2, 2016
lakewood, California
I just finished dropping the rear sub frame in preparation of changing the rear diff bushings.
Anyone have experience pressing the new bushings in? What did you use between the bushing and the hammer to drive them in without marring up the aluminum part of the bushing?
I made a make-shift press out of a pipe cap, threaded rod, two nuts, a couple washers, and plenty of grease when I replaced my sub-frame bushings last year. Using a hammer will not allow the bushings to set in straight. It worked well for the diff bushings and subframe mount bushings.
Here is the press I made (Home Depot):
Here is how to use the press:
Bushings went in no problem. I was too lazy to find bolts and washers so I just used 4x4 blocks and a 2lb beater.
