What the f**k?
Teflon
133
Mar 2, 2008
Blackwood, New Jersey
Any ideas on how this happened? There were no metal pieces anywhere to be found, the pistons were fine and untouched, the valves were fine and untouched and the spark plugs were all intact. I'm lost.
You must have had a low spot there and it finally burned through over time.
Sent from my SPH-D700 using Tapatalk
yes you became lean and slowly torched the gasket and head.
the head is savable tho, some welding, a bit of blending and a good surface job and you will be fine.
Rebuild a completely different head or find someone to weld it and grind/smooth it back down then just resurface the head. Up to you on that one but I would just get it welded. it more than likely (depending on the weld job) be stronger afterward anyhow. Looks similar to a dry shot nitrous blow out.
Holy crap. That is some serious shit there. I am not into the drag scene much but that had to be some serious power going right there.
My initial thought would be that detonation killed the fire ring in that area, and that allowed the flame front to creep in between the head & block at that location. You were lean (thus the detonation), and the high cylinder temps began melting the aluminum in that location. I would guess it was pretty well vaporized when it went though the turbine wheel, so no damage there isn't a surprise. Are there any pock marks on the piston or quench pad that would indicate you were experiencing high levels of detonation?
I'd check the block surface between those two cylinders as well. Typically when it's this bad, the block has a gouge in it as well. But yeah, the head is repairable.
my dad did this with his chevelles motor. the headgasket blew from the nitrous and crossfired between cylinders and it looked just like that but through the block and head surface....
good luck on the expensive fix:thumb:
