What size injectors to use?
FirstCarIsA GSX
126
Dec 20, 2010
Riverside, California
I am looking to purchase injectors to go along with my new Evo 3 Big 16g. I am looking to try and get between 300whp-350whp and the tune will be done by RRE. I currently have 550cc injectors and am looking to upgrade, so what size should i go?
well i wont be using ecmlink because RRE will be tuning the car and the data logging and stuff will be done with evoscan. i was thinking 850cc's but i wasn't sure if they would be overkill or not enough to max out my turbo
You know, instead of spending tons of money on Link, you can just purchase a Tactrix Cable and tune your current ECU just as much as you can With Link, Minus buying an Ecu ($200+/-), Link ($150/600). And ECUFlash (What you'd tune with if you tuned your ECU) is free minus the 160 dollar cost of the Tactrix Cable (unless you buy used) is Speed Density Native (Which costs 545 bucks Minimum From ECMLink) (Map Sensor, not MAF). All you need is the sensors to convert over and newbish wiring experience. But to each his own.
Back on topic. In my experience I've seen people use 750cc Injectors on a Big 16g for Max Efficiency of Turbo and Injectors. Just so the Injector isn't maxed out for the boost levels being thrown at it. Since Maxing out injectors isn't really a good thing. I've seen great results from the Evo 560's personally and I'm about to start tuning for 850's on my 20g.
I honestly say 750cc's for a big 16g and tune the hell out of it and enjoy your lovely stock looking, Ass Whoopin, Turbo Setup! :D
I dont see the point in what half these people said, unless you want a shit idle, or you plan on doing a huge project down the road to get some serious numbers and what to save your self buying another pair.
LOL @ anything more then 700cc's for a 300-350whp setup.
