What should I do next?
Sik95TSI
246
Feb 18, 2011
Manteca, California
Can you guys check my mods list and tell me what you recommend getting next? I have about $2300 to play with!!! I'm either thinking LSD or a rotating assembly! What do you guys think? Any input would be great! Thanks! :eagle:
1g throttle body and possibly intake Mani. Pretty sure your mods list had intercooler/tubing. Actually be able to move some air from that t28 to the PnP head.
That's a start.
Yeah I have the punishment racing FMIC kit! Well it's not a daily driver it's just a pleasure/drag car. Well I heard stock manifold is good for about 500-600whp.
Goals are 400-450whp by the way.
List of ideas to make more power -
-Sell 850cc injectors and get 1000cc injectors
-Upgrade to V3 full-
-BC 272 cams arent the best but they will do, you will make better power with gsc s2 cams.Also didn't see if you upgraded your valve springs, it's not listed in your profile.
-Sell the T28 and get a bigger turbo like a fp30 or hx35/40 for your 400hp range
-Build the bottom end is what I would do.Everything else seems fine nothing really else to do.
go ecmlink full v3
forced performance intake manifold with coupler to go to your t28
and build a six bolt forged internals.
speed density dundle from ecm link.
add e85 go fast.
your out of cash.
No E-85 I'm running 100 octane and I also have a AEM meth kit that I havent installed yet. I don't want to do a 6bolt I'm sticking with my 7bolt.
Intake Mani is a great drag upgrade and I'd match that with an hx35/40. Run low boost or rebuild bottom end if you can afford it.
Well my car is FWD :-/ so I need to put this power to the ground too! My springs and valves are in tip top shape! So I'm really looking for something I really need! I know for sure my turbo eventually
Well my car is FWD :-/ so I need to put this power to the ground too! My springs and valves and tip top shape! So I'm really looking for something I really need! I know for sure my turbo eventually.
FWD is the best!I guess you can get a lsd.Prothane motor mounts if you don't mind a little more vibration.Mostly you should look just upgrade your turbo.
buy some nice rims and tires :thumb:
I would def. go with a lsd orrr....awd swap. But honestly your fwd so if your gonna go fast yoy mune as wellget a good spring and retainer set so yiy gave a decent powerband up top. Or a good rotating assembly to match that built head. Or decent rod bolts at the very least....just my 2¢
Yeah well it's getting Dyno Tuned in about a week i'll let you guys know what it puts down! I'm defitnetly between rotating Assembly or LSD..... :talon:
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
