What should I be making?
banshee04
126
Nov 22, 2008
Midwest City, Oklahoma
Im sure you guys get alot of these, but i just wanted to see if you guys could possibly tell me what i should be making under these circumstances.
Mods:
Frank level 4 turbo
HKS 40mm wastegate
SMIM
DNP exhaust manifold
Fmic
750cc Inj
Rebuilt head
91 pump gas
I have someone who is gonna tune my car that is just awesome at tuning.
So if I have an awesome tune, 91 pump gas, and however much boost i can run with out detonation, how much should I be looking at?
WAYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYy too many factors to even tell. What level of boost are you running?
I would like to run how ever much I can with pump gas. How about 25 psi.
As stated above there is way too many factors to be able to tell you what kind of power you will be making.
To me threads like this are absolutly pointless kind of like bench racing.
Mods:
Frank level 4 turbo
HKS 40mm wastegate
SMIM
Fmic
750cc Inj
Rebuilt head
91 pump gas
Well, if he tunes it on a dyno you'll know then...
The engine has new everything except rods, and pistons. Let's say the weather is 70 degrees, humidity 60%.
Im just saying, what should a healthy engine make under these circumstances. Give or take some HP
Again not trying to be rude but there is just too many variables.
But if you want to get some kind of idea you should search through this section to find a setup similar to yours.
DSM Dyno Sheets Database
I looked in there, it was a little help but not much. I know that my turbo is very similar to an FP Red, but the turbine size on mine is just a little smaller. I saw a Red in there that made 416whp on pump but had a 2.3L. So Im probably looking around the 350ish AWHP.
