What kind of numbers should i be looking for
Status
Not open for further replies.
bluebuggy
Apr 19, 2008
new albany, Indiana
I looking at my first DSM i would like to see what you guys think of the set up or should i change some stuff
thanks
the car is a 91 fwd
4G63T 2.0 turbo.
Turbo is a 16g
Poly motor mounts
650 cc FIC injectors
Walboro 255 lph fuel pump
SAFC
KYB AGX adjustables
Greddy boost gauge
2.5 down pipe
3 cat back
Its a real basic setup an seeing it has injectors and safc it must have been tuned. Do you know who tuned it? What air fuel ratios its hitting or what boost level its at? Does it have a wide band o2 sensor installed with gauge?
not sure about any of that really but i asked the guy yday about the wideband and boost no email today and he has been tuning i think im looking to get in to DSM and tuning as a hobby just trying to get a feeling about what kind of power numbers i should hope to see with this setup and a good tune
do you know which 16g is has, big, small, plan old 16g
First off start researching a lot on the cars. You have a boost gauge. I would do a run and make sure its holding 10-12psi at most for now just to be safe. Make sure you look at the gauge around REDLINE to make sure the turbo is not creeping to a real high boost level which can happen on that turbo with larger exhaust. Its very dangerous to have boost creep and if you dont know these cars, buying a modded one like that can fail if you dont know what to look for.
Status
