What rings to use?
jdmspilner
118
Dec 19, 2004
Houston, Texas
Im gonna do a simple re-ring to my motor and I was wondering what I should use, I was leaning towards Mitsu OE but should I use somthing diffrent?
Those should be fine, thats what I used. Please rehone the motor though.
Steven
I did a simple, cheap re-ring on a 4G63 once, and I used Sealed Power rings. They worked fine. Sealed Power, Hastings, or OEM all seem to work good. Make sure to correctly file fit the rings, and to hone out the cylinder walls to ensure proper ring seat. Make sure not to hone too much as you can bore out the cylinder if honed too long. 3-5 quick passes is all it takes.
in all three dsms i have had i used summits gapless rings less than 1% blow by,but they are alittle more pricey.but OEM is great also.
I just went to Advance and picked up some Beck-Arnley rings and have had no problems... $87 after tax. I did not hone and i have absolutely no blowby or oil loss or smoking at all. Quite a few guys i know have done the same. Look here concerning rebuilds and especially cast vs. "chrome" rings.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
