What line goes where on 14b turbo?
S_Ranger
Banned Member
761
6
Aug 30, 2004
ca, Central America
I had a manual where it showed in details what line it is and where it connects to. Does anyone have a pic they can scan or something resourceful to show this description?
I am guessing you are asking about the water lines since the oil lines are pretty hard to mess up. The line that comes from the water neck goes to the front of the turbo and the line that comes from the thermostat housing goes to the back of the turbo.
So water line ON the turbo are across from eachother. If you notice the oil return line is at the bottom so that would mean oil feed line is on top of turbo, vertical of the return?
Also, the only line I have stock right now is the water line to the back. I noticed it uses a banjo fitting with a banjo bolt. So will the other water line right? How is the water line re-used from the t25 if the fittings on the ends are different?
One more q,
This ss line I'm getting has a fitting to bolt up to the turbo but not the oil filter housing. It's bare waiting for something to get threaded in...
what kind of fitting do I get?
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
