What is B16g Trim???
DSMpwr25
110
Oct 29, 2004
Gloucester, Virginia
Whats the trim of a B16g, and were and how much would it be for another air side?? the one i got is messed up, bent fin and chip one. thanks
There are no "Trims" in Mitubishi turbo-land, just ID numbers. I.E:
-tdo4 "series"
-tdo5 "series"
-tdo5h Turbine wheel
-tdo6 "series"
-tdo6h turbine wheel
Your big 16g compressor wheel will ID out like this:
-tdo5 B16g
These wheels can be acertained at almost any DSMturbo retailer I.E. Forced Performance, or Slowboy Racing.
Good luck!
Trim is just the exducer divided by the inducer. So a 16g is about a 50 trim.
it's a little bit more than just simple division... I don't have the exact forumula handy but yeah. The 16G isn't a 50 trim. The 50 trim can flow enough to support 475 HP w/ race gas on a good tune. So the trim of the turbo isn't going to tell you what it flows.
You can replace just the compressor wheel. You dont need a whole new CHRA. Just send it to one of our trusted vendors for a new compressor wheel, and a full rebuild and balance. :thumb:
I will assume compressor since the Turbine is the same on each...
Small16G:
Ind. 1.825
Exd. 2.360
Big16G:
Ind. 1.893
Exd. 2.675
EvoIII16G:
Ind. 1.903
Exd. 2.675
Trim is just a slang term used by people, it really doesn't mean anything.
Because it is a ratio it all depends on the wheel size.
If you use the example above, a person with a small 16g could say they have a 60trim which is correct, but then a real 50 trim (in dsm terms) would be much bigger and capable of more hp.
Make sense?
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
