what head gasket
Gsxhero
86
Jul 7, 2012
santa rosa, California
Im sure this has been coverd but maybe not to my specific budget. I would like a mls head gasket. I got about $100 to spend. i already ordered arp head studs. im finding alot of graphite head gaskets. I saw Felpro PermaTorque 4G63 Headgasket but it is double what i have to spend. I was running 16psi and i plan to keep it under 30psi if that matters....i would like to atleast upgrade from stock while im in there. TY all. :thumb:
I would keep the arps and grab a oem one or a felpro they will be able to hold up to your goal, grab one from any auto store the felpro for your car, and spend the extra money somewhere else.
Fel pro composite HG 9627PT about $40
Been proven to over 30psi and 500+ HP
I believe if you use some copper spray you can get by without resurfacing, but only if your block and head are pretty straight to begin with. I have done it with a felpro mls and didn't have any problems. Someone will correct me if I am wrong.
TY all. yeah hopefully i wont have to do any machine work. I'd like this to be fast and easy. What does MAP stand for SOdakgsx? also ive been searching myself, but if anyone can link some good gaskets that would help alot.
Modern Automotive Performance = MAP
They are a supporting vendor here
The Fel-Pro PermaTorque gaskets come from the factory with a coating that helps seal the mating surfaces of the head and block. Copper spray would coat the gasket, and wouldn't allow the the facing to form as good of a seal as originally intended. I wouldn't ever use copper coating on a head gasket.
If you haven't used Rockauto, I'd recommend checking them out. I usually get most of my stuff from them when doing a rebuild.
FEL-PRO Part # 9627PT Head Gasket for $25 bucks
I run the felpro permatorque mls also :)
I've used both. The MLS hold boost better but are harder to seal coolant generally then composite. I do copper gasket both sides of MLS gasket. Both hold boost very well. If you already have the head off and have the ability to get to a local engine machine shop I would get the head checked with a straight edge. My local shop doesn't even charge me to do it anymore cause Ive been there so many times but its usually no more then 10 or 20 bucks. Just a tip to help you out. You don't have to do it but I like knowing I don't have any warp. If you have a Machinist straight edge you can do it yourself with a pair of feelers gauges.
