what do i need to know
highrever
45
Mar 14, 2011
thompson, MB, Canada
HI there i am new to dsm's i just recently purchased a 1996 eagle talon tsi awd.
and was wondering what are some important things i need to know and aslo
what are the best moderate but great horsepower adders for these cars. I know
that a better intercooler would be a hp adder but not sure what else? i want to
acheive about 260 and up hp at the wheels. also wanted know if their were some
secret power adders from other 4g63 cars that might bump my power. so tell
me what you guys think, that would be great thanks.
1G BOV
FMIC
550cc Injectors
255 Fuel Pump
Adjustable Fuel Pressure Regulator
Turbo's: 14b, 16g, evo3 16g for the power level you suggested.
MBC
DSMLink V3
DP
Catback
Pretty generic but people have made 260whp with less. Good luck.
First off, an intercooler won't benefit you any (will also NEVER add horsepower), in near stock form you will actually lose performance because of the pressure drop across it.
Secondly power adders- You're new HP bible: Tech Guide: 2G 4G63t Upgrades - DSMtuners
1G BOV
FMIC
550cc Injectors
255 Fuel Pump
MBC
DSMLink V3
DP
Catback
This is a good list, but if you're just looking to make 260 you won't need an FMIC. Also if you do choose to get DSMLink, which I would suggest, get the biggest injectors you can. Also look at the tech guide it's great help.
^^^ I am assuming the OP is on a budget and the FP BT-28 is very pricey at $832.00. My opinion not worth it when you can buy a Evo316G for $499 plus $175.00 for the install kit. $675 total for a turbo combination that shits all over the T-28. of course a 16g or a 14b can be had for cheaper but to each his own.
But both the 16g & the 14b have more lag than the FP BT-28 that's for sure.
Maintenance first very good point if you want a little hp for free cut your ac belt, you can take it out to shave a little weight along with the space tire in the trunk.
id get a 14b, ported everything, 550s and mbc, catback,
a intercooler wont add power. if its too big then you can loose power. you should do the maitence first. like timing and pullys waterpump. but after that you can get a catback, 550 , 14b ported mani
like others, i'd suggest MAINTENANCE first or else your car won't be going anywhere haha, timing belt, water pump, all fluids etc. then exhaust, hard IC piping and a 14b or 16g with link and injectors and such
