What do I need to do.
GreedyDaniels
May 2, 2009
puyallup, Washington
I have just purchased a 1990 Eagle Talon, and I need to know what I need to do to get the most out of this car. I know absolutely nothing about these cars accept they have tons of potential. I need to know proven bolt ons such as cams, intake, injectors, fuel pump, and any other forced induction trinkets. All help is welcomed. Thanks.
First thing you need to do is make sure all the maintenance on the car is good. Compression, timing, plugs, wires, ect.
Then check out the tech section. Tech Guide - DSMtuners
One thing that is always good to do is a search. Most of the time you will find your answer much faster just by searching. Good luck!!
Start by reading everything you can under the "Tech" section that is in the upper left-hand menu at the top of the page. There you will find answers to FAQ's, upgrade paths you want to follow depending on your goals, etc. The first thing to do after reading those sections is ALL of your maintenance first. Then start doing the modding.
Oil change, plugs and wires, new belts including timing to start with. I've done a lot of little mods to my car and what I've seen the biggest noticeable difference in performance is more boost. Go ahead and get you a boost gauge (stock is not accurate) and a mbc. Just research research research before you do a mod, and worse comes to worse ask on here everyone is more than willing to help you.
