What did you do to your DSM today?
Made wire harness' for gauges. Realized PO didn't have Water temp gauge hooked to anything. Just 12V/ground for some fancy blue lights. :hmm:
Made bracket to hold turbo timer to lower dash. Powdercoated TT bracket.
Gave A-pillar pod a couple shots of Krylon satin black.
Installed gauge pods/gauges. Wideband sure was fun.
Mounted turbo timer.
Mounted EBC in glove box.
Wrapped wires under dash with electrical tape/zip-tied them out of the way.
Reinstalled airbag.
Installed leather e-brake boot.
played with the engine harness. evo 8 ecu going in, so may as well strip whats not needed to run the car. and removed solder connections. Head work is next on the list
Removed front and rear strut bars, replaced battery and terminals. Next is to replace 3in intake pipe with stock one and remove fuel lab fpr and install stock one. Trying to get this car pretty much back to stock except for suspension, turbo, gauges, and exhaust. Just going to need to source a smic and piping then all should be done with it.
Pulled clutch master cylinder.
Dis-assembled it and cleaned 18 years of gunk out of all the passages/reservoirs.
Put some of the steel brackets/clips into a vinegar bath in preparation for powdercoating.
Rebuilt it with OEM kit. Looks brand new.
Took my car out and beat the living piss out of it playing in the snow....litterly put away wet!:p
Drained a quart of oil to make room for some Lucas oil stabilizer to hopefully alleviate my low oil pressure at idle. Also squirted some WD40 into my evap purge solenoid in the hopes it will start working again.
I replaced my fuel injectors in (-40) weather today in my driveway at night not fun, The tools were even colder but after what shoulda been 20 mins (took 1hr 30 min), My cars running like a champ again. Oh and i got a speeding ticket 246$, 15 km over but the officer can't write and spelt my name wrong so im gonna fight it! wish me luck.
That's definitely something I do not miss, working outside in winters a B*tch. Congrats on get'r done tho!
What I've found when ever getting pulled over is if you can pull over as soon as you know the cops coming after you, turn the car off, interior lights on, and have all the paper work ready to go before he even gets out of his cruiser. They usually really like that and charge under the minimum amount, I've yet to get a speeding ticket that's the set price + $1 for every Km/h over. My last one 2 years ago was $140, minimum charge is actually $185+. Usually if they spell your name wrong you'll win in court 9/10, good luck!
Oh yeah not fun in th winter haha , I pretty much had everything ready I was going to work so it was early and still dark out I just pulled right over ( car running) and waited he wrote me a tickt and asked if I had any questions told him nope not my first ticket and he left then i noticed he spelt my name wrong and forgot the rs turbo thts on ,my registration so taylor was driveing a plqmouth laser when it shoulda been tayler driveing a plymouth laser rs turbo ( he acually put a q in plymouth) and a O instead of an E in my name
Cut the clutch hardline into 6 pieces for easy removal.
Pulled Brake Master Cylinder.
Pulled ABS prop valve.
Started trying to figure out this mess of ABS lines. (I will most likely cut them out tomorrow)
Ordered MORE parts LOL.
ordered a fidanza flywheel, took bumper off to get it on the ramps for r&p, clutch change. and to put some other parts on it.
Damn the man! He probably just pulled ya over cuz he's (or she's) jealous that they don't have a DSM! Good luck in court!
  • For sale ACT clutch 2600
    • Briant91
  • For sale 2g 2G OEM Rear Passenger LSD Axle
    2G OEM Rear Passenger LSD Axle &125 + shipping & paypal feesYou must be registered to see...
  • Wanted 2g 2g awd rolling shell
    I’m looking for a clean 2g awd rolling shell.
    • DSM_Thorpe
  • Wanted OEM Front Mud Guards
    ISO 1GB Eagle Talon OEM Front Mud Guards
    • Cj Anderson
