what cams should i got with
Don't get BC cams, they make awesome stuff but their cams got short changed. Go for HKS 272's, Kelford 272's, or FP2 Cams and you'll be good for a solid 400+ with them without sacrificing drivability.
:dsm:
The only way you're getting down to $300 is used.
Ive got a set of HKS 264/272 with 7K street miles. Good midrange cams for a street car, PM me if you're interested.
see i did 315 cam on my old toyoda and it was way to much for street plus i had chevy valves and had to cut the 40 over teflon piston. i dont want to do that agen
I disagree if you look at delta cams I think the come out in the 300-400 range and they have been tested to show some pretty good results.
Here's a guy that did a test of the deltas, http://www.dsmtuners.com/forums/cyl...est-delta-hks-272-delta-k272-bc-272-cams.html
I think these would be your best bet if your looking for something cheap but good.
Look around for a set of used cams if your trying to save some money, I bought my FP2 grinds for $330 shipped. All the cams lifted above will "drop in" so to speak, without any modification to the stock valve train.
:dsm:
My HKS cams are being replaced with Delta K272s. They were about $370.
Like i said, the only way the OP would get to $300 is used.
ya go for the delta! i picked up my kelford 280 cams from them for 350 and there exact replicas of the true kelfords and made from billet cores there not straight regrines! good deal and good cams had good luck with mine so far!
