DP got a hole what should i do???
SinEclipse
766
Jul 31, 2004
San Diego, California
Well this thingy broke off the dp and still hangin under my car but when it broke off i saw that it took a chunk of metal with it now theres a hole. i got a long dp so no cat. is it possible for rre to cut the dp and install one of there high flow cat. on?
take it to a muffler shop to get it welded.
should be no more than a 35 dollar fix.
Thanks for the quick reply. I want to put a cat. converter on tho so would it be a quick cut and weld or is there gonna be extra modification to put the cat on?
if you have your own cat, it should still cost the same because you wouldn't need new hangers or anything.
the shop should be able to cut it and then flange for a cat (will cost you extra) but you can then have them make a straight piece withthe same flanges. This will allow you to choose if you want to run a cat or a straight pipe that day.
thanks alot. i would run a straight thru but since i live in cali. smog and emission here is strict so i'll be putting a cat. on to be safe.
