what boost should i run
90laserdsm
45
Sep 17, 2011
Schwenksville, Pennsylvania
i have a fwd laser. the engine is stock but rebuilt. i have bc 272 cams, evo 3 16g, 550cc injectors, 255 walbro, fmic, 3" turbo back exhuast, evo springs and retainers. i was wondering if any one has a similar set up and if so how much boost should i run to get the best power. right now im running stock boost to break the engine in.
Ok good. Im in the same boat you are then. I have a set of 550s and 880s just sitting :toobad:. As a reference, Im running a bastard 20g on a 255 pump at 14 psi. Thats really pushing it. My wideband shows 10-1 A/F but my plugs say otherwise because im over running the injector. 12psi Seems to be my safe zone. Id wanna say 13-14 should be your max. Go no higher. If you wanna be safe the 12 psi should be fine for the 16g.
i have all the supporting mods i will need. im planning on getting link by summer time. so ill just keep the 450s in and keep the boost stock until then.
@hardcorandy do you go to the oaks meet? becuase i think you were there last time i was. were you the one who was gonna get the car painted and just got the 20g?
