how much boost should i run?
iammikesevvy
30
Nov 15, 2006
howell, New Jersey
Heres my set up
Engine - Completely rebuild engine with eagle rods and wesico pistons, and hks 272 cams
turbo evo III 16g
fuel- walbor 255 pump and 660cc injectors
exhaust - 3 inch piping all the way back and buschor racing manifold.
also got dsmlink
im currently running 16psi
You should be able to get away with about 23psi on that turbo, then its going to push hot air with more. Basically turn up the boost and watch for knock, timing,and air fuel. Nobody can really tell you how much every car is different. Tune the car as best as you can.:thumb:
Run as much boost as you can before you start to knock. Then, either start to pull out some timing or lower the boost. If you don't already have a wideband. Get one. Make sure to keep your AFR around 10.5-11.5:1 while on pump gas.
