what are the stock fan specs
spawn87
908
3
Dec 6, 2007
sacramento, California
Ive tried looking on search for the specs of the stock radiator fans (95-99 turbo models) but all i find is the write ups for slim fan instals.
im looking to find out how much amps each fan uses. im planing on making an electric fan kit along with a controller unit for another project car and i want to use my stock fans i just want to make sure they are below the 25amp limit or if i need to upgrade the relay.
thanx in advance.
Use the stats off the OEM relays, they are seperate for either low and high or by each fan. That would be the simplistic way. and remember stock fans have 3 speeds .there is the low coil winding the hi winding and then kickiboth on at once for 'speed 3"
yeah i knew about them been 3 speeds but pretty much only use up to speed 2 if needed.
so if i want to wire them both to run speed 3 should i assume i gata stack the amp ratings from each?
