talontsiboy24
- 868
- 3
- Mar 28, 2009
60457,
Illinois
My air fuel ratios at idle are 14.6-15.1 and wot 10.7-11.0 at 22-24psi is this good?
Well its gonna lean out i have a boost leak right now so i should be even better once its fixed.thats a good safe tune. You could probably lean your WOT out some more. 11.2 is a good number
It all depends on how much timing you're running. Some cars make more power with more timing and richer AFRs while other make more with less timing and a leaner mix.
Well all i have is a custom chip in the car right now its just how i bought it these are some of the stuff on the chip 8000rpm rev limit,680cc injector compensation and deadtime, 2g mas compensation, custom fuel and timing maps. Octane reset, fuel cut removed. How can i tell how much timing is being pulled?
Well if your alternator is on its way to death can it mess with your air fuel ratios?
They usually say about 36 inches from the turbo, so about 3 feet. The closer to the turbo the more accurate reading your gonna get, but you will lose life on the sensor. Also you will mount it on a slight angle facing down so there is no water build up in the sensor.
If you're shooting for max power, it depends what your timing curve is like, how efficient your intercooler is, and plenty of other variables like EGT's, outside air temp, etc. This is why tuning is so crucial, and a good tuner is so valuable....they must calculate all of these variables on every car they tune sometimes without the proper monitoring devices. Remember- if tuning were easy, everybody would be good at it.My air fuel ratios at idle are 14.6-15.1 and wot 10.7-11.0 at 22-24psi is this good?
