koroshiya_jason
- 0
- May 23, 2005
Klamath Falls,
Oregon
i'm going with an external wastegate off of my evo iii manifold, and i was just curious why the existing exhaust passage for the internal wastegate needs to be welded shut. it seems like i should be able to just disconnect the vacuum line running to the internal wastegate, and without a pressure source the internal wastegate won't open. or maybe run a second mbc set slightly higher to act more or less as a safety device in case the system overboosts... any advice/suggestions would be appreciated.
