Deadpool25
- 37
- 0
- Oct 17, 2012
Phoenix,
Arizona
Ok so when im at a stop and i take off i here water running in the firewall or somewhere near there has anybody come across this and what is it?
you may have a leaking heater core or clogged evap that. now you will have water/coolant sitting in the bottom of your evaporator box, when you are coming to a stop or taking off, you may be hearing water sloshing around. are you low on coolant or can you smell funk in your a/c ducts?
the only other way to figure out what is going on would be to maybe drill a whole in the bottom of your evap box, but that doesnt necessarily fix your problem. it may allow the water to drain out, but the issue is that the water getting there in the first place. you dont want to have water draining into your floor board. with your climate in AZ, its dry heat right? you may not get a smell for a long time because of the low humidity. best thing to do would be pull the dash and see what exactly is going on.
could be slow leaking heater core, could be a cracked drain hose or evaporator core. does your a/c function properly?
I've been hearing the same sound. Around 3.5-4.5k RPM it sounds like water behind the dash. Never did figure out why, it doesn't seem to affect the car but it bugs the crap out of me.
I had the exact same issue on my 420A. Now I know I'm not crazy.
