Weird noise
Backinajiffy12
504
Mar 31, 2008
Shakopee, Minnesota
I have a weird humming noise coming from my engine bay. :ohdamn: This noise is new I've never heard it before, I'm thinking it might be my tensioner or my harmonic balancer. And sorry if I posted in the wrong area I never know where to post :nono:
YouTube - Weird noise coming from engine bay of 4g63t
and go easy on the color comentary that goes with the video
Take a long screwdriver to your ear and place other end on objects (like water pump) to locate noise source.
+1
This works really good just put the handle to your ear....not the sharp end.:p
Sorry I couldn't resist!
It does work really well though. I work in a power plant and everywhere you go its loud so this is almost the only way to tell if a bearing or something is going out and keeping your hands away from stuff that can eat you up at the same time.
ok thanks guys I guess I could also mention that my srs light has been coming on and i was told that could mean my alt. is going bad and my battery did die today so alternator could be seizing up maybe?
Did the good ol screwdriver to ear test today at as many points as I could an it was strongest at the alternator which im guessing is seezing (<--- spelled wrong) up, I also believe its going out because of the SRS light going on and off and the radio started going in and out right when this started to happen. So now the real question is do I go buy a new alt. and put it in in the parking lot at school or haul it home to MN and find one back home. just gotta find a car trailer now instead of renting on from uhaul
thanx for the help guys ill keep you updated after I replace the alt.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
