waltah
- 372
- 159
- Mar 2, 2011
fairfield,
Virginia
Will these engines run at all with one of the camshafts 180 degrees out?
I have a parts car which was said to have been driven several hundred miles to where I bought it, then shortly it 'lost power,' then the new owner started working on it but lost interest. Then Craigs List, a deal, and it got trailered here. I've swapped most of the interior, the rear bumper, just finished swapping the A/C evaporator since the avatar car one was leaking but it's really too good a car to simply scrap -- it looks grubby, lots of minor stuff but there's little rust, only minor body damage other than that. So I thought I'd see if the engine runs. Tonight I tried to line up the timing marks and when the exhaust cam sprocket mark points toward the intake camshaft and is level with the deck, the mark on the intake cam sprocket points toward the rear of the car -- not toward the exhaust camshaft.
Tough to wrap my head around this. The exhaust valves would be open during the compression stroke so there wouldn't be much mixture there when the spark hit it. Could it possibly have run that way? Or did the P.O. mess up the timing as an early step in his 'working on it'?
