Tyeler18
- 2,568
- 368
- Dec 16, 2008
Casa Grande,
Arizona
Ok to start off: 1990 Talon AWD TSI, MBC, Boost gauge (t'ed off at the vacuum line for the stock FPR) Basically all stock other than that.
Bought the car none running because it wasn't getting fuel. Previous owner rewired the fuel pump when he replaced it with an bosch OEM replacement and it wouldn't start after that. I redid the rewire the way the VFAQ says to do it and at the relay it gets 10v, but doesn't kick on the fuel pump, so I wired it to a switch to the battery and it gets 13v to the relay and DOES turn on the pump. It has fuel up to the fuel rail (taking off the FPR it will start to run out after 5-6 seconds of the pump being on), it has spark and compression (compression was real low at 105-110 across the board, but it will start/run for a few seconds on starter fluid).
With the key "on" each terminal on each injector pigtail gets about 14v (have a battery charger on the battery) and about 2.5v when bridging the voltmeter between the two terminals and cranking. I pulled the fuel rail off, hooked it up with the injectors facing upwards towards the hood and tried cranking the car and they won't spray. Tried a different set and they do the same thing. All the injectors ohm out at about 2.9 ohms and I've tried 2 different OEM fuel rails, and 3 different OEM FPR and nothings getting them to spray.
I've spent the past week searching and have had search overload. ECU is an eprom that has been recapped in 05 and shows ZERO signs of leaking or burning. I've been checking voltage on ECU pins, but I've read so many threads on which to check that I can't even remember what I'm checking anymore.
Any help?
Any help?
