- Thread starter
- #26
Archer Fabrications
- 9,719
- 706
- May 9, 2011
Scottsdale,
Arizona
Thanks tim, i do plan to keep the ebreak. I know there is a ton of wiring to remove bit how do i trace all that back without disassembling the whole harness? For instance mu SRS ECU plug, i can get rid of all that but I'd have to unravel alllll the loom and such and tape it all back. This is something inwant to do some day but dont have enough time to do a project like that right now hahaRemove them. If you haven't already, and want to drop some more, lightweight front/rear brakes. If you don't have a need for the E-brake, remove it, and all the associated hardware, brake dust shields, cables, lever assembly and bracketry. If you intend on keeping your factory E-brake, then at least remove the dust shields from the fronts, if you haven't taken apart the rears its not worth trying to fully remove them and destroy stock axles/hubs until they break or are too worn.
There is alot behind the dash you can pull, and a TON of wiring that can be removed.
it's 14lbs
