2G Water Pump Question
Unless it was damaged in some way you don't have to change it , meaning you dont have to buying a new one Obviously you will have to unbolt it and swap it onto the new pump (4bolts).
Thank you. I've done my share of timing belts and water pumps but never have had a seized pulley. I figured it would be the same but just wanted to check. Again, thank you.
So I have everything off and the car is just sitting in my garage waiting for a new water pump. I had to ship one in from Vancouver so it's 1-3 days till I can get started. Anything else I should replace while I'm in there? My timing belt is 100% fine, less than 2000km on it. I already got new powersteering and alternator drive belts.
