GSLENK
- 1,416
- 56
- May 25, 2011
DC,
Maryland
I am replacing an engine and need some advice on what to do about the OEM oil cooler sandwich plate thing. I would love to delete it (cut off thread portion of the ofh/oil filter bolt) and be done with it. (90's style housing, no cooling).
My engine threw a rod, and there were metal chunks of all sizes in the oil pan. I am assembling the external parts of the new engine and I realized that the oil cooler may have chunks in it. OEM replacement is $350+ and I am unsure if it is even available.
I am aware that the "oil cooler" also acts as an oil heater. Also keeps stable oil temperatures.
Delete Pros:
More space. One less stupid ugly coolant line. No chance of loosening/crushing/etc/mix oil-water...
Delete Cons:
Oil will take longer to heat up (water heats up faster)
Oil may overheat?
I run valvoline VR1 racing synthetic 10w30 in the winter, 20w50 in the winter. (I do not recall if the 20w50 is synthetic or not or if it is a blend)
I change it pretty religiously (always well under 3k miles, more like 2000-2500 miles) and I have tons of oil on hand I buy in bulk at sales.
If I do delete it, I will likely not be adding an air/oil cooler setup. (requires 90 OFH to do correctly)
Can the OEM water/oil cooler be cleaned? Should I be worried about contamination?
Delete Pros:
Delete Cons:
Oil may overheat?
