Wastegate actuator for 7cm housing
Dr Ronald
69
Jun 5, 2011
Fort Wayne, Indiana
I recently replaced my turbine housing. I have a big 16g which had a 6cm housing. It now has a 7cm housing. The problem is that the hole on the wastegate actuator is now too small for the arm on the housing. Should I just drill the hole a little bigger or doo I need a new actuator?
No it isn't the wrong one. Any tdo5 actuator should work on any tdo5 turbo. I would just put some washers between the actuator and the compressor housing to shim it closed. There should actually be spring tension holding it closed.
    • Sdcryan1
