walbro 255 question
TC Mueller
169
Jun 23, 2006
Bartlett, Illinois
As im sure all of you with the 255 know what im talking about when I say "the whine" but just a question. When I am at a stop light and have my turn signal on the whine sort of pulses with the turn signal. Is that supposed to happen or am i drawing too much power?
My car does that too. It's funny how many people make :confused: face and say "what's that?" when they ride in my car.
That is normal, re-wiring the pump will help.
Agreed, you can do the battery re-wire for about $15 and it will eliminate or greatly reduce the wine from the fuel pump. There are kits on e-bay or you can build your own kit.
Ya Im with the others if you haven't rewired the pump already thats probably the issue. The fuel pump power supply from the factory is very lacking. Fuel pump flow is directly voltage related, so its always a good idea to rewire no matter what pump your running.
Yeah the pulsing of the Whining nose is do to voltage osilation (i cant spell) from the turn signal going on and off caused by how the factory wires are run. If you rewire the pump that should stop.
I have the ebay rewiring kit and it worked fine for a while. Now, I added a kill switch in the middle of the starter wire coming from the positive battery terminal. Now my pump oscillates again and I'm not sure why. I do have it on the same side of the split starter wire that is connected to the positive terminal. Would this possibly have to do with it starting to make more noise again (since it's not connected DIRECTLY to the positive terminal)?
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
