Viper 5701 Install Help
iguanahotsauce
238
Dec 13, 2010
Vancouver, Washington
Alright so I ordered a Viper 5701 System off ebay and it finally got here today. There are a couple wires I am unsure about where to connect. They are parking light output, 30 amp fused Ignition 1 relay input, and 30 amp fused accessory/started relay input. For the parking light one I know the wire is green with a white stripe and runs along the side of the radio housing, what I was wondering is what polarity it is. For the last two I read that they should be connected to a constant 12v source but I'm not sure. For the ignition relay it says "This wire is the polarity feed for the Ignition 1 relay" and for the accessory/starter relay it says "This wire is the polarity feed to the accessory and starter relays" and here is a link to the installation manual http://www.toyotatundraforum.com/pdf/Responder LE Model 5701 Installation Manual.pdf
Man I own a shop and do two remote starts a day and am an authorized dealer and I dont understand a single word your saying please retype this so I can attempt to assist you.
^ LOL. i installed car audio/alarms for years and am not really getting it either. sounds like hes looking to tap the 1 green and 1 purple starter wires and the pink switch power wire?
Bro IDK about you but it sounds worth his time to take it to a profesional shop. IDK though I could be wrong I mean he does know its a smart idea to own a DSM :)
Sorry if I was unclear in my first post LOL. What I am trying to figure out is how to hook this up correctly. So it comes with six different harnesses. From what I have read in the installation manual I don't need the auxiliary harness, the door lock harness, and the Remote start auxiliary output harness. Correct me if I'm wrong. As of right now this is what I know where to tap into:
System Wire Car Wire
TRUNK RELEASE OUTPUT Red/White Not Used
12v CONSTANT INPUT Red White
SIREN OUTPUT Brown To Siren
LIGHT FLASH White/Brown Not Used
CHASSIS GROUND Black Ground
DOOR TRIGGER INPUT Violet Green/Red
TRUNK PIN Blue Not Used
(-) DOOR TRIGGER Green Not Used
DOME LIGHT OUTPUT Black/White Not Used
TURBO TIMER ACTIVATION White/Blue Not Used
PARKING LIGHT OUTPUT White Green/White
GROUND WHEN ARMED Orange Not Used
IGNITION 1 INPUT/OUTPUT Pink Black/White
(30A) FUSED IGNITION 2 Red/White Not Used
ACCESSORY OUTPUT Orange Blue
STARTER OUTPUT Violet Black/Yellow (Car side of Harness)
STARTER INPUT Green Black/Yellow (Key side of Harness)
FUSED (30A) IGNITION 1 INPUT Red ?
IGNITION 2 Pink/White Not Used
FLEX RELAY INPUT Pink/Black Not Used
FUSED (30A) ACCESSORY/STARTER INPUT Red/Black ?
NEUTRAL SAFETY SWITCH INPUT Black/White Ground
TACHOMETER INPUT WIRE Violet/White White
BRAKE SHUTDOWN WIRE Brown Green
HOOD PIN SWITCH INPUT Gray Hood Pin
2ND STATUS/REAR DEFOGGER Blue/White Not Used
Ok so What I need to know is where to connect the Red wire on the 10 pin harness and the Red/Black wire on the 10 pin harness. Also Do I need to tap into the car side of the ignition harness for the ignition and the accessory? If so is there a way to get easier access to the car side of the harness? Because I can barely get to it and it is almost impossible to splice into from how hard it is to get to.
I found the wire locations and colors from vfaq Visual Frequently Answered Questions - Home Page and the installation manual is here http://www.toyotatundraforum.com/pdf/Responder LE Model 5701 Installation Manual.pdf
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
