vibrations like crazy high rpm
brian102
142
Nov 6, 2010
coldwater, Michigan
I never let my car rev above 3k because i get this terrible grinding vibration noise. Some people mentioned balance shafts i dont know if car still has them or if belt has ever been changed how can i check if they are still there. What else could it be. Has 108k miles. Its a bad enoiugh noise where i never rev it above 3k or it makes me nervous ill try and get a video of it. Thanks
Man, same thing happened to me. I would pull the pan and look for balance shafts and to see if there is any play were the bearings are.
Well you have to pull the pan to see them up in the block. But you look for metal in the pan.
I believe you can possibly remove the engines, timing belt cover to see if yo DO have balance shaft belt installed.
