Very weird problem, feels like fuel cut.
fredom dsm
328
49
Jan 31, 2006
Denton, Texas
Hey guys, I recently Upgraded to a small 16g, everything was fine for about two months, it was a total difernt car, it pulled really nice, but now when Im boosting it feels like fuel cut or thats what I thik, I turned the boost down to 13 to 14 lbs and it's still doing it, I had it at 15lbs with no fuel mods, I just now used a Snap-0n scaner and it came up with the folowing codes: P0170, P0505, P1103; The last code said: Turbo charge waste gate solenoid malfunction, What does that mean?? the first code didn't show anything. what should I do???
Thanks.
I upgraded to a 16g also and i have a EBC and mine runs fine i do agree with the above comment bypass the stock BCS and Just use the MBC to control your boost...just as an add i no this is not safe but i have creeped up to 17psi to redline and still no Fuel Cut so i would do a Boost leak test why your at it to make sure that you dont have a leak make the fuel to cut off.
