1G Very uneducated
Wonkytsi
3
Jun 5, 2017
Saint Joe, Indiana
Hello! I just picked up my first turbo car a 1990 talon tsi awd, but I'm very new to the whole scene love cars but no nothing about them. I picked this car up for cheap $500 but now I can see why it was. This kid murdered the car ripped out all interior not in a smart way either and the engine is basically held together by tip ties from what I seen. So she is rough. Big plans for her. I am just trying to get it driveable atm. The current problem I am having now is that i am not buikding any boost. The fella said it ran fine. [Probably shouldn't take his word] but I am getting vacuum but higher Rpms it's like it's cutting out. Please help. All new to this
Boost leak test the intake tract from the turbo and I bet you will find leaks. Use a spray bottle with soapy water to spot leaks. If you can't test, go around ALL of the couplers between the turbo and the throttle body and tighten them all up.
I guessed there was a boost leak somewhere just didn't know where to start. But I will try that after work.
Already ahead of the game. Good to hear :)
Now when you say breaking up, do you mean the car has no power when this happens? Does it completely die, no power? Does it hit a limiter? Or does it still continue to pull while breaking up?
the car idles just fine. But when you give it some gas the vacuum won't pass 0 and it will start shuddering really hard.
When you say you give it gas, I take this as, you are trying to set off with the vehicle? Or you are driving the vehicle and you go to give it gas and you cant get past 0 vacuum?
Driving it. I get to sb9ut 3500 ish rpm and it just shudders. I'm sorry for the ignorant responses. Haha. But yes the vacuum just stops at 0 and won't start to build boost.
Chances are, either the turbo is shot or you have a crazy boost leak somewhere. Take off the intake and see if you can move the internals of the turbo. There should be minimal side to side and hardly any in/out movement in the turbine shaft.
Gotta agree with the above ^^^ :thumb:
Had a buddy come look at it. Big dsm lover he says the turbo is blown lucky I picked up a evo 3 16g the other day! Thanks for th3 helo!!
