LaserRS92
Supporting VIP
- 318
- 29
- Aug 14, 2008
Fort Wayne,
Indiana
Ok, I have a 92 Laser RS AWD 5spd. Has installed an ACT2600 clutch with sprung street disk, oem throwout bearing, clutch fork, and pivot ball, and extended slave rod. Car has 850 miles on this setup since it was pulled from Detroit and rebuilt. When the trans came out of the car after sitting for a year it had a broken 1-2 shift fork and two shims under the clutch pivot ball. With the act2600 clutch those two shims caused the clutch fork to hit the pressure plate. Both shims came out to fix that.
Drove car as is for 850 miles, clutch was real low on the floor, releasing right off the floor. Slave died next. In went oem unit with dorman clutch master, extremepsi braided clutch line, and extended slave rod off old slave. After gravity bleeding system and the pump up bleeding style the pedal is just as low before, no improvement at all. Feel is improved from braided line however.
Question is, is there a pressure plate that would be shallower or something and allow the pivot ball shims better than my current act2600, is it flywheel runout issue, or would a new trans fix things since every trans is different?
