ACT2600 pedal engagement issues
kinkz1g
Jul 25, 2006
Palatine, Illinois
hey guys, i recently replaced my clutch with the 2600, but now it seems like if i dont smash the petal all the way to the floor, i will grind. is this supposed to happen?any feedback on this would be great. thanks.
you need to get a slave cylinder extenchen rod you can get them on ebay and slow boy racing for pritty cheap
the clutch doesnt grind, the gears grind, because if its not fully on the floor, then you cant switch gears. thanks for the help
Follow SlowSpyder's advise and adjust the clutch engagement point. You will have to turn the master cylinder rod clockwise to raise the engagement point of the clutch. Try to get it to engage about 1/3 of the way off the floor.
Weird......I just did this last night when I replaced my Master Cylinder. :p Damn thing was leaking all over the carpet. It's a good thing that I blew up my boost gauge, or I would have never seen the leak.
