clutch pedal is very soft. help me please!!
Stainbox12
378
7
Jan 3, 2006
Panama, Central America
my problem has been going on for a while and i need some serious help. my clutch pedal is very spongy, like it has no pressure, i checked my lines for leaks and found none. i recently replaced the master and the slave at the same time. i also pulled the tranny out and shimmed the pivot ball with a washer. i took out the whole pedal assambly to check if it was worn and it was fine. i don´t know what else to do, the TOB looks fine and it works, the fork is not bent at all, the pivot ball looks fine. i´ve bled this thing to HELL!! and still nothing. can someone give me some advice, is it probably the pressure plate/clutch/flywheel? i really need help on this one. BTW i´ve searched and searched and had found similar problems but they were fixed with the solutions i posted above. i can´t shit in any gear though.
I have a centerforce clutch. the weird thing about this, is that it worked fine before with the stock rubber line. I have bled the hell out of this thing.
  • Wanted 6 bolt NT water pipe
    • chrisman287
