Clutch pedal is soft?????
19grip90AWD
Sep 28, 2004
Osage, Iowa
Ok, i just got my car back together and we were bleeding the clutch but the pedal wont stffen up it just feels like the gas pedal. So i was wondering if something could have gone wrong or what please respond with any ideas thanks inadvance
-Rob
has it says in my message the "car" is hwat i put back together and the clutch is not gaing pressure from bleeding it. So i was wondering if anything could be worng has if in i didn't do that procedure correctly cause i htink i did. Pushe3d in the clutch pedal released the nut and then tightened the nut then i let the pedal out and i repeated this step many times and no pressure.
yeah dude if u bleed ur clutch and its still soft it means the piston in ur clutch slave cylinder is worn. u can buy a new slave cylinder for 40- 60$ and install urself C:\Documents and Settings\Owner\Desktop\Slave Cylinder for the Clutch.htm :thumb:
