2G vertical oil splatter all over the driver side
jonablzgst
Jul 14, 2015
Belize, Central America
hey guys. i would really appreciate your guidance to what might be happening here..
oil is all over. its all smeared with oil...when i while the oil off..and start d engine again, it doesn't get squirted with oil...but as soon as i go out in the streets and go driving for 5 min and come back home...i have this issue. what can it be guys? the oil pump gasket not good? HELP please..
my timing belt is dry. i don't fave the top timing cover,. just the bottom piece. but the belt is dry. what is the ring blowby?how do you check for oil compression? thanks in advance! its my first DSM.. :/
there is some oil coming from the front side of the block..but from the driver side area
It is possible to have oil leaks on the timing side without having observable oil on the belt. I would still pull the cover.Additionally, if you had the front case off during your service, you can have leaks from there, or the OFH. How is your oil pressure?
oil pressure should be good... there is no light of oil on d dash. i probably need to take that cover as soon as i can..
Looks like it coming from the ofh area, look at the drip coming off the sending unit. Could also just be the oil pan. Does the oil pan have a gasket or just rtv?
it has a gasket and RTV on it..but it has some bolts that are broken. like three of them.
Likely your issue....
Hopefully not indicative of the work that was done. If so, there could be more than one leak.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
