driver side axle seal help
tarheels23
101
May 15, 2011
struthers, Ohio
Trying to replace it and I can't figure out how to get it out, and does anyone have part numbers for parts stores?
I would order one from mitsu but they're delayed because of this damn hurricane and all the ones online have stupid high shipping charges
After you get the axle out, take a screw driver and pry it out. You should be able to get one at about any parts store. Take the old one in there with you just to make sure that they give you the right one.
What stores do you have local to you? Sometimes the seal will look slightly different, as long as the outer and inner diameters are the same than it will work fine.
have a pep boys, autozone, advanced auto parts, and orielly's. but autozone doesnt have any. advanced had one but it just looked like the passenger side.
Thats why I was trying to see if anyone knew parts numbers other then the factory md719710
I know the factory part number Id order it through mitsu but theyre delayed because of the hurricane and I cant really wait for a seal to come so I can put my transmission back in and the part store prices are way to much. Ordering them online is just as much for an oem part.
Autozone part number is 710199 for 16.99
orielly has 710199 for 28.99
advanced has nothing
pep boys has none.
So I guess I pretty much answered my own question. thanks for the help
You need to ask for a timken, 710197, or an sfk 14028 . Those cross from the oem part number. If you have a local seal and bearing store they should be able to find you one. It should be like a 5 dollar seal.
