vaccum leak near throttle body
GettinPaper
289
Aug 31, 2009
Battle Ground, Washington
I did a boost leak test and i can hear it leaking around the throttle body area... I sprayed soapy water and can't see any bubbles coming out of my throttle body area... I was thinking my FIAV O ring seal??? The EGR is removed and blocked off and the vacuum lines on the throttle body are capped.. What else could cause it to leak around the throttle body?? Any help is MUCH appreciated.. Thanks tuners.
The shaft runs through your throttle body. On one side is the cam your throttle cable attaches to and on the other side "front of engine side" your tps bolts to the throttle body. Hiding the end of the shaft. Did you pull the hose off the pc valve and see if it was coming from there?
What do you mean pull the hose off the PC valve and see if its coming from there??? I'm confused..
To check for the shaft seal leak, rock the part of the TB you would push to rev the car. If you move it around and the sound changes, probably shaft seals. Underneath or around TB, closest things are BISS, intake manifold gasket and lower injector seals. My bet is shaft seals. You'll need 91-94 seals because the 90s are a little different.
